Vegas Smith
20+ Year Contributor
- 5,191
- 3,108
- Dec 2, 2002
Houston,
Texas
My lc2 worked perfectly fine when I installed it (as evidenced by the first log I'll post) then the car wen't down for a while, I changed it to the front o2 spot, and now it won't work. My gauge reads fine apparently but in dsmlink my lc1wb only reads 20.7 and never changes. The gauge and controller box are both connected to the front o2 input into the ecu, so I don't know how two wires with the same source read differently. Like I said, when it originally worked it was hooked up to the egr (I believe) and now it's hooked up to the front o2. I'm directly looking at the solder joints and it's certainly connected. Thanks for any help.
