SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
No
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
COP or Stock Coil:
Wire brand and Age:
Spark Plug brand, type and Gap:
stock coils, ngk n7s gapped 0.28
5). Motor health (Compression Test)
Cylinder 1:155
Cylinder 2:155
Cylinder 3:155
Cylinder 4:155
6). Performed basic throttle body adjustments?
Idle Switch:
Throttle Cable:
TPS:
BISS:
7). Compression ratio 8.3:1
8). Any known bad sensors or brittle wiring?
9). Any DTC/CEL codes?
10). Electrical system
Car off (not running):
Car running:
Base Fuel Pressure:43
Injector Size (cc/min)te 1000
Sensor Brand:lm2
Calibration Date:1 month ago
13). Type of fuel
Type:
Percent of Ethanol:ms100/93 mix
14). Watched ECMlink how-to videos?yes
Now that my injectors duty issue is resolved the took the car out and turned up the boost. Im starting to loose traction in 2-3 gear with 17inch enkei with quality tires. I cant believe how hard the car is pulling. each time I return i check compression and my plugs. The motor has 150 miles on it give or take. Just wanted to show you guys my progress
No
yes
yes
4). Ignition system
COP or Stock Coil:
Wire brand and Age:
Cylinder 1:155
Cylinder 2:155
Cylinder 3:155
Cylinder 4:155
Idle Switch:
Throttle Cable:
TPS:
BISS:
Car running:
Sensor Brand:lm2
13). Type of fuel
Type:
