2G 6-Bolt swapped wiring and Connectors
TunedUp
204
12
Dec 28, 2011
Newport News, Virginia
Hello Everyone,
So, I have my car mostly back together after replacing the clutch, and the turbo. I have ran into the issue that I didn't label where the connectors go, and it is a Full 6-Bolt in a 2g. I have a FSM for my 95' Talon and I have the one for a 92' Talon. I am very savvy in reading diagrams, but they are no help or I am retarded. I have looked over both Electrical FSM's and with the wiring the previous owner did I can't tell what is what. Does anyone have a link to a great guide showing where all the connectors go, or can someone help me via pm's that way I can send a picture of each connector to find out where it goes. This wouldn't be so hard if all these connectors didnt look the same. I mainly need help for the passenger side harness. Also, I found a ground that is about 6" up the harness from the starter that I am not sure where it goes. I want to say thank you in advance as I have a headache from trying to figure this out. If this has been covered I apologize, but I have looked through other people asking similar questions and they don't seem to answer what I am looking for.
V/r
Brandon
Awesome thank you ! This helped tremendously, but I still have some that are on that list that there is no where to plug them up. Are there some connectors that are not used in a 6-Bolt swap?
Okay getting them now. I will edit this post with the pictures. Ugh waiting on phone to charge some so I can upload to cloud drive then post them up.
Other than these connectors the only other thing I don't know about it the ground that is about 6' inches from the starter on the starters portion of the harness. I can't get any pictures since it is up under everything.
First one looks like the cam sensor harness and the last one looks like the cruise control plug. Ill have to go look on my talon tomorrow to see about the other ones, they look familiar but cant remember what they went to
The three pin rectangle connector should be VSS or the MDP.
The two pin oval connector might be a fog light connector. Or the knock sensor.
The four pin square connector looks like o2 sensor or a fan connector or cruise control.
The last one, whose shape is hard to describe, is the starter solenoid connector. It plugs into a wire coming off the blade terminal on the starter solenoid. Might be what you mean you say ground by the starter?
This all going by memory as my harness has been stripped to the basics and assuming plugs haven't been hacked in from other harnesses. The first 3 can also only be confirmed by their wire colors as those plugs are used multiple times in the harnesses.
For some reason I never got notification that I had replies. Anyways I have figured everything except for the ground out.
This is the ground that I can't seem to figure out. Any help is appreciated!
Okay sweet bolted it to the transmission with the top starter bolt. It actually was bent to almost right on the bolt so I feel a little retarded. Thank you for the help!
