miliman13
- 1,957
- 276
- Jan 1, 2011
tampa,
Florida
1). Any boost, vac, or exhaust leaks?
40psi hold
2). Verified mechanical timing?
yea
3). Verified base timing?
yes
4). Ignition system
oem .
Bpr7es .28
5). Motor health (Compression Test)
Not measured yet.
6). Performed basic throttle body adjustments?
solid
7). Compression ratio
9.5:1
8). Any known bad sensors or brittle wiring?
no
9). Any DTC/CEL codes?
no
10). Electrical system
solid
Base Fuel Pressure:45
Injector Size (cc/min):750
Sensor Brand:aem
Calibration Date:....
13). Type of fuel
93 pump
14). Watched ECMlink how-to videos?
With a passion.
If you have seen my build thread, then you know my stuff is on point. Yrs of mistakes and patience has lead to this....
So this is a light conservative WOT tune.
I have no intention of going past 8psi for right now. Because shes still less than 500 miles from rebuilt.
This is simply so i can have a little smile while i daily "granny" drive her, so i can break her in... Yes eventually i plan on hitting 30psi and seeing were i land.
This is my question...
At around 4-5000Rpm AFRest suggest 9-10AFR but many threads suggest 11-12AFR on WOT....
So i leaned out a little to reach 11, i began to knock. So instead of adding fuel i pulled timing and reduced knock.
1) Is this the right way to go about this?? How would you do it??
2) Should i always match AFRest(on wot) no matter how rich it gets? it suggest pretty rich at times.
3) I Got high KNOCK at 3rd gear 3kRPM For some odd reason..... i dont know if its because i started my 3rd gear pull so early, since i didn't see that on my other pulls were i started WOT a little after.
Thanks guys, I'm exited to finally be here..
P.s Boost matches all data.
Before any adjustments
After Today's pulls
Knock Log
40psi hold
yea
yes
4). Ignition system
oem .
Bpr7es .28
Not measured yet.
solid
9.5:1
no
no
solid
Sensor Brand:aem
13). Type of fuel
93 pump
With a passion.
After Today's pulls
Knock Log
