Sachsline
- 93
- 2
- Jul 27, 2016
Aberdeen,
South_Dakota
how do I get my isc set at 30? I had it at 30 but was stupid and decided to ground with ecmlink to make sure my biss was adjusted right and now it reads this. isc test good, ecu is good, tps is good. I am new to this and would apreciate some knowledge, I also have a 3rd gear pull with knock at 7 degrees 5k rpm? I assume that's not normal, I will post that log too. how do I adjust my fuel/air to get the counts down? 1). Any boost, vac, or exhaust leaks? Boost leak tested 5psi above your max boost with no leaks? all good
2). Verified mechanical timing? yes
3). Verified base timing? yes
4). Ignition system stock
COP or Stock Coil:
Wire brand and Age: accell
Spark Plug brand, type and Gap: brp7
5). Motor health (Compression Test)
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
6). Performed basic throttle body adjustments?
Idle Switch: yes
Throttle Cable: new
TPS:yes
BISS:yes
7). Compression ratio
8). Any known bad sensors or brittle wiring? not that I'm aware of, no issues
9). Any DTC/CEL codes? no
10). Electrical system
Car off (not running):
Car running:
Base Fuel Pressure:37
Injector Size (cc/min):559cc
Sensor Brand:stock o2
Calibration Date:
13). Type of fuel
Type: 92 oct
Percent of Ethanol:
14). Watched ECMlink how-to videos? over and over
COP or Stock Coil:
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Idle Switch: yes
Throttle Cable: new
TPS:yes
BISS:yes
Car running:
Calibration Date:
13). Type of fuel
Type: 92 oct
Percent of Ethanol:
