RipperXX
20+ Year Contributor
- 5,790
- 165
- Feb 23, 2003
Royston,
Georgia
About to find out, sort of got lucky, it was marked manufactured in 07/2015 so they gave me a 20% discount, ended up being just a hair over $100 so I said screw it and bought it since my old bigger battery was leaking vapor at the postitive post and cording the crap out of my terminals.
It's been sitting so long it's not fully charged, so I'm charging it, assuming it cranks the car once fully charged fine. I'll be modifying the OEM battery tray to sit a lot lower but use the same mounting points at work Wednesday when I go back to work. (we got today and tomorrow off for Christmas) I brought a bathroom scale in the store with me , got some a couple odd looks, but soon as i picked up a battery and sat it on it, you could see it click in their heads. This was the lightest battery I could find between O'riley's, Advance, and Wal-mart. Napa was closed so I didn't get to see what they had as an option. The battery it's replacing was 29lb, and I have no idea what it's CCA rating was, but it was a couple inches longer and probably 3 inches wider. I'm betting it was 550 or so. I'll update soon as I find out if it will start the car well. It will stay on a trickle charger in the shop in my back yard so its small size doesn't worry me.
On a side note, anyone have any idea what kind of plastic the factory battery box is made out of? Wondering if I can cut material out of it, and use some sort of glue (or heat) that would "melt" it and enable me to "glue" it back as a smaller box that fits this battery. I'll be trying to modify that box reguardless as well as the OEM tray and hold down, so it will all mount lower, so it's not just lighter, but weight moving lower.
