GsxEcutioner
- 1,579
- 4
- Sep 3, 2007
San Bruno,
California
Just got this kit today for my 95 4g63t. Is the belt supposed to show the fibers? Is this ok or not?Follow along with the video below to see how to install our site as a web app on your home screen.
So the car has about 90k on it. Should i just go and replace the belt or everything belts and pulleys , water pump ? How hard of a job is it ? I've been looking at vids and they seem pretty complicated especially for a 4cyl
Any tip is appreciated
Study up on the vfaq and write ups. After you do a timing belt and tensioner correctly on a DSM you can consider yourself a mechanic
On a scale of one to ten, it's a ten. Because of the precise measurements required and the special tools needed, it is not something you should expect to knock out in 6 hours if this is your first time doing a timing belt and water pump
You should also replace the cam seals and crank seal.
Belt doesn't typically matter on brand, but you should use an OEM hydraulic tensioner assembly
But how do you install it CORRECTLY .... That's the biggest question. Im bout to do mine soon , just bought a dsm so i gotta go over everything on the car since the previous owner didnt know jack sh**. I used to own a Z33 and everything on it was really easy to work on, its my first dsm so its a whole new ball game to me
Yea its just hard to torque everything to spec thats all. Ive done numerous job on my Z33 so im not exactly a noob , im just trying to do everything at once so i dont have to reopen it up again later on. Should i change my cam gears and cam shaft while im at it too ?
Im putting on a new big 16 Evo lll so i might as well change them. Time wont be a problem since i got a spare car, i just hope nothing goes wrong thats allIt is not necessary to change out cam gears/cams while performing this job. You should, however, inspect all of the seals. It is much easier to replace them now.
Nah im just putting it on since i got time, im not even planning on pushing over 15psi , i just like to get everything done at once and i dont beat on my car. Im keeping the car for good after all, cant hurt this babyUnless you already have a fuel setup to support over 20 psi on a 16g I would not skip steps and get ahead of yourself. That money for caMs and gears would be better spent on dsmlink
