ceedawg
Supporting Member
- 1,528
- 215
- Nov 9, 2002
laurelton,
New_York
Other than the brake lines, the 3g booster and MC were basically plug and play!
Well the mc is yeah but im doubting the booster is as thats the same as the evo and as ive said many times before the pivot part needed adjusting and if the 3g is the same length then that also means the pedal moves in alot and takes away pedal distance!Other than the brake lines, the 3g booster and MC were basically plug and play!
I don't know what to tell you other than I had no issues same as many others who have installed the booster but make it work however you can and let us know how you make out.Well the mc is yeah but im doubting the booster is as thats the same as the evo and as ive said many times before the pivot part needed adjusting and if the 3g is the same length then that also means the pedal moves in alot and takes away pedal distance!
Im just starting to get this sorted and im going to make a new pivot adjuster so i can get back my 5mm ive lost in travel, easily done and no biggie to do. Fab skills to the rescue haha
Went through 80% of thread I am dismayed as to how very little is mentioned about the after-installation performance comparison of these brakes!
Anybody cares to express their experience - on performance? Comparing what you had before, and whether it was worthwhile the effort (beside the look of Brembo caliper on an Eclipse)?
Thanks
Just the general perception has to how these brakes perform on a typical dsm...
Do people feel a significant improvement on their stopping ability comparing to the OEM ones?
What about the rotational mass? Has anyone feel their car being sluggish after this mod?
Thanks
Thanks
Thanks
Thanks
That's 1 way to say it's a great upgrade hahaI'm not typical, but my experience may still be relevant but you must be the judge for yourself.
When my car was a street car and I moved from OEM brakes to Stoptech 328mm front brakes there was a very noticeable difference in braking power. This would be similar to what you get with an Evo 8/9 brake setup. I loved it. My street pad compound didn't change, so this really was just the front brakes alone changing.
Move to a few years ago. Now my car's a full blown race car with the best pads available (in my opinion). I pretty much out brake everything, even the vastly lighter cars on track. I was still on the Stoptechs, but the thermal mass wasn't enough and I was cracking rotors every weekend. Thanks to ec17pse (buy your Galant knuckles from him, he's awesome) I moved to Evo X front brakes solely for increased thermal mass, expecting nothing to very little from the larger diameter rotors (roughly 350mm). I sh** you not, same brake pads and everything, the brakes went from really good to feeling like I threw an anchor outside the car. It was f'ing awesome. Just... amazing. I could not believe they were that good. I still can't believe they're that good at their price point.
Take those anecdotes for what you will. Do I think they make a big difference even to your average dsm? Absofinglutely.
Thanks
I doubt many or anyone will pay for the SS pistons upgrade , the seals are great but hate brake fluid . You using RB's pistons and seals aswell?To me the OEM setup, especially AWD, is undersized for the weight of the car. The significant improvement comes when you have the right pad/rotor paired with the Brembo setup (calipers, lines, booster/MC). With stopping ability, it will down to mostly pad choice, but the additional clamping force certainly helps. Cheap pads on a Brembo setup will not improve the stopping ability over the OEM DSM brake setup with quality pads. In addition to the feedback above, the Evo Brembo setup has a huge variety of choices when it come to pads and rotors to suit the operating climate of your car. If you were concerned with the additional roatational mass, you can go to a two-piece rotor setup with no modifications running the Brembo setup. Also, there are some great rebuild options should you need to abuse them. Racing Brakes makes a SS vented piston and high-temp dust boost for the Brambos in an effort to reduce heat transfer to the fluid. There are also multiple companies that make titanium shims/backing plates as well. I had to replace the dust boosts every other track day due to heat.
I'm different I love to buy the small detailed things to make it special haha. I ment it as in the others on here most likely won't pay for them even though they are well worth it.Coming from a guy that runs this himself!
Yes I have them, just waiting until I need a rebuild. Unfortunately, the setup is not going to a DSM.
What's it going on then? Spill the beans, can you do me a favor, as I forgot to weigh mine can you weigh the different sizes if they are Evo sized or close to it please,
Evo X uses bigger bolts so which ever way you go make sure the bolt holes are big enough,This one page has soooooo much information on why one should go this route. Thanks so much guys.
I currently have the old/discontinued AEM big brake kit for the front with stock calipers and Axxis semi metallic pads all around. But now I am highly considering the Evo calipers and probably the one from Evo X. I have had this car for 18 years now so probably it will be a good idea to upgrade to the 3g master cylinder and the brake boost as well.
We need a thread on which "light weight" rotors and pad combo is the best for these brakes...
I have full interior (at the moment) when I had my xp10 and xp8 pads it stops sharp! As you most likely have read before I find it was too front bias, but the pads do work amazingly well! Once I get my pedals in I will have full control over the bias, if I cannot then I will run xp10 front and rear.Thanks for this info. I'm sure those 350mm rotors make a huge difference. I have the Stoptech setup but now Im intrigued with what you are saying about the Evo X setup. And you guys are recommending the Carbo tech pads if that's what they are called correct? (Roadracing full iterior)
