JDR7919
- 301
- 0
- Jan 1, 2005
Titusville,
Florida
Im going to the track soon for the 1st time. I was wondering what gear you auto guys are cross the 1/4 in? I think I read somewhere its not good to shift into 4th/OD
Will I not need to worry about shifting to 4th?
Block: Built 2.0L
Eagle Rods
Wiseco 9:1 Pistons
Polished stock crank
Line honed mains
Kiggly main girdle
ARP Mains/Rod Bolts
ACL bearings
SS Figure 8 O-Ring job
Head:
BC 280 Cams
Ferrea +1mm valves
Kiggly beehive springs
Titanium retainers
3 angle valve job
Ferrea valve guides
Evo 8 rockers
Fidanza cam gears
S90 Throttle body
Turbo:
Holset billet HX40 60mm
44mm wastegate
TIAL 50mm Q BOV
Budget beefed up manifold.
JMfab Garret 4" core Intercooler
Nitrous Express Proton Wet kit
Transmission: 1G Auto
Kiggly front clutches
Ipt end clutches
Translab shift kit
Welded center diff
Kiggly mod
Stock restall converter
Kiggly flex plate
B&M PRO Ratchet shifter
Block: Built 2.0L
Eagle Rods
Wiseco 9:1 Pistons
Line honed mains
Kiggly main girdle
ARP Mains/Rod Bolts
ACL bearings
Head:
BC 280 Cams
Ferrea +1mm valves
Titanium retainers
3 angle valve job
Ferrea valve guides
Evo 8 rockers
Fidanza cam gears
S90 Throttle body
Turbo:
44mm wastegate
TIAL 50mm Q BOV
Ipt end clutches
Translab shift kit
Welded center diff
Kiggly mod
Kiggly flex plate
