tittiesmcgee
- 2
- Jun 2, 2016
milroy,
Pennsylvania
Starter is stuck engaged. Not in the forward position. Spins with no keys in the ignition. As soon as I touch the positive terminal it draws power. Any ideas.
Have you swspped something else recently? You are incorrect on the 6 vs 7 bolt teeth count. Its fwd vs awd and its not possible to put a fwd flywheel on an awd. Did you have a bad stsrter and that's all you swapped or did you do a motor or trans swap recently?I feel like my bellhousing isn't for a 1g. I think the bell housing from a 2g turbo is swapped onto my trans. (Justs a guess, might be wrong. I know something out of the ordinary is ammis) since the flywheel has a smaller diameter. and the 2g bell housing is bigger to accompany the extra tiny bit of room for them extra 4 teeth on 2g bell housing its not grabbing. 7 bolt has 110, 6bolt has 106. I really think that combined with some trans swap or machining mistake ignored by the previous owner is my issue. Especially since both the bolt holes don't line up for my new starter. (If anyone wants to act like I commited a sin. Yes when I tried to turn my car over my starter only had one bolt in it. Its fine. Dont be mellodramitic. It wasnt going anywhere.) (No I didnt buy the wrong starter) As a matter of fact one i bought specifically for my car today doesnt fit. Which dissapoints me. Because I gave the original to the guy at the junkyard for the first one I got to cover my core charge. Nothing to compare it to now . Thank you to the two of you whom actually tried to help me. I've bought 3 starters this week . I'm talking about 4 starters if anyones curious. Original, junkyard, I swapped out for another one at the yard. bought a brand new one today when that didnt work. Hard to follow sorry.
