DsmDanielson
- 104
- 0
- Jul 13, 2016
Peoria,
Arizona
First off, yes I am new here. Already know to use good grammar, etc. I just need some help. I'm new to Dsm's so please bear with me thank you. Check profile for car info. So I bought my dream car 2 weeks ago. Had a bad ecu sensor ground, swapped ecu. Changed maf... STILL THROWING P0100 CEL?!? Also throwing codes for rear 02 (knew that, its gone), wastegate solenoid, and evap. Car runs like absolute crap. Won't boost over 5psi, (probably boost leak but could be limp mode), there's an oil leak from my spark plugs as well. What's really killing me is the maf. I checked the connections, changed maf with known good one. Also, I noticed the car won't run on karman. It will start up and instantly die. Its on hotwire right now but I know that's not right since I'm using stock 2g maf. Please help me this is my dream car and I knew it would be problematic but this is insane. I did search and couldn't find any results. I just want to be able to boost...
