19gsx91
- 1,199
- 295
- Apr 20, 2011
Walworth,
New_York
After some discussions with FP and JuxMX I may have had a blown oil seal on my turbo which would cause some further problems with my paticular setup as far as spool goes, It has been sent out for examination/rebuild and I will update you guys when I know what the cause is. In the meantime I will be upgrading to a set of FP2 cams and finally getting my headgasket/ARP head studs in and will be able to turn the boost up to my desired goal of 25-28psi, I'll see how the 16g holds it, and because I have this kind of time on my hands I will be switching back to the v2 68hta to see how it likes high 20s for boost rather then it sitting right around 20psi.
Not that this is a great measuring stick but I always found 1st disappointing in the 68hta, Id stomp on it and nothing happens until I'm so high in the RPM range I have to shift VERY quickly after it actually hits boost.. right now set at 22psi in the 16g If I stomp on it in first the car scrambles for a second when it hits boost with a brief amount of wheelspin and I'm grinning ear to ear as I take off.. Again though, I am biased towards a "torquier" car then I am towards a top end car. The 68hta felt stronger on highway pulls but after reviewing my logs It's hard to say because Gofer was right about my timing tables, Had I run a modded 1g table to begin with in the 68 my findings could have been vastly different.
