dgdsm
- 173
- 4
- Aug 24, 2008
Tarzana,
California
I did recently an axle shaft replacement, and took apart the suspension on this car for the first time. After tightening up the suspension components and replacing the outer tie rod end, the handling and steering is just about back to what it was before the axle replacement. The steering and handling aren't exactly where they should be, and this being my first time doing suspension work, I have the following concerns on the suspension setup:
(1) The replacement outer TRE was just a little bit shorter than the one I took out. I installed the TRE by matching the # of turns with the one I pulled out, I'm not going to take it to an alignment shop until I at least do the other axle, but might do a DIY toe alignment.
(2) I couldn't pop the lateral lower control arm ball joint, and just about all the grease was pushed out with the application of the pickle fork.
(3) A lot of the grease is also pushed out of the other (compression control arm) ball joint.
(4) To get the damper fork holes to line up correctly, I loosened the bolt to the shocks and adjusted. So that adjustment is different right now than where it was before the axle installation, and the bolt is also undertorqued at the moment.
(5) The axle nut was installed and tightened with an impact wrench and isn't torqued properly right now.
(6) On both sides, I found the boot on the inner tie rod end to be split so at least these need to be replaced.
So in general the questions/ concerns are about how safe are in the present condition and what absolutely needs to be replaced? I believe it's possible to replace only the ball joints without replacing the suspension component. I've driven about 100 miles so far with this driver's side axle installation, and the steering and handling now seem pretty much as it was before the replacement. There could be some subtle issues on steering control at higher speeds. I'm not planning to do any freeway driving until things are tightened up a bit more and probably not until replacing the other axle.
