1G 1g Wing Hardware
knochgoon24
DSM Wiseman
6,135
92
Jan 29, 2008
Troy, Michigan
I'm in need of these little fasteners. Does anybody know the part number for just these, or know where to source a set new/used?
These each hold a nut for the 2 bolts that lock the wing in place once it's slid on. As you can see, mine have seen better days.
When I had that problem I didn't want to deal with old used ones cracking. I cut up some steel I had laying around the garage to fit in the little tabs that hold em in, drilled some holes, tapped em, threw on some stick-on weather stripping stuff, applied some thread locker, and bolted em up. It's been solid for years. I know I've got some photos on my laptop.... Maybe I'll write up a short article on it.
Update: I replaced them with pieces of aluminum flat plate. Tapped them for M8 bolts. Used a nice glob of silicone and an oring under the bolt head. Seems to work alright. I could probably have used a couple washers between the plate and the trunk to make the wing mount a tad flatter, but oh well. At least my hatch no longer leaks.
