airbats801
- 1
- May 3, 2014
tigard,
Oregon
I could use a bit of advice on which housing to choose with the hx35 8 blade. I'm trying to build it to spool as quick as possibe, and that's why I want the .55 mitsu bep housing, but I'm a bit worried about it choking the engine at high rpms.
Engine eagle rods, wiseco pistons, 1000cc injectors, cyclone intake Co trolled with ecmlink, speed density, hks 272 cams, crower springs and retainers, evo rockers, hks cam gears. I'll be running a tubular top mount turbo manifold as well. I'd like to see power up in the mid to high 7krpm, but I also want it spooling fast as its going into a 4x4 truck.
Will the .55 mitsu housing choke my top end? I know it limits flow to around 50 lbs or so, but unsure if it actually hurts on top end power
