tylor2015
- 49
- 1
- Feb 8, 2016
Blacksburg,
Virginia
95 talon tsi fwd far as I know motor is stock. It has 255 fuel pump adjustable fuel pressure regulator a header an 3in exhaust, big front Mount intercooler an a 16g turbo. Question is what is the most it could boost. Idk of the boost gauge is hooked up right cause every since we ran the nipple on the j pipe to hook the blow off valve up right with the electronic boost controller I'm hitting 20 to 25 pounds boost when I get down on it an there no fuel cut out or anything. When I got the car the guy didn't have blow off valve working at all an all the pressure was coming back through the air filter pipe.
