TheFlashDSM
Supporting Member
- 1,082
- 312
- Feb 18, 2010
stony brook,
New_York
i just dropped off my parts at my local machine shop SK-speed in Lindenhurst ny, so i need an answer ASAP so i can tell him what to do for the head work
machinest says he has done the 4g63t motors before and that they wont hold 40psi of boost, that the head gaskets smush out of place,
question: what should i use to hold 40+psi on my motor not rotating parts or head parts, im talking details like head gasket, o ringing, head studs (over-sized), head specs, things like that,
so i need some advice from someone who made killer power with over 40 psi of boost
bottom end parts,
99 block,
99 stock crank,
howard i beam rods,
acl bearings,
wiseco hd 9.1;1
blueprinted and balanced,
head parts,
Supertech 96lb Dual Valvesprings Retainers,
GSC Power S3 Billet Camshafts,
Ferrea Competition Plus +1mm intake, exhaust,
Ferrea Exhaust Valve Guides
keepers,
turbo borgwarner s400
dual walbro 450
2150 injectors,
e85,
automatic,
dsmlink v3 full,
aem cam gears,
custom t6 manifold twinscroll,
dual 44mm tial waste gate
bottom end parts,
99 block,
99 stock crank,
howard i beam rods,
acl bearings,
wiseco hd 9.1;1
head parts,
keepers,
dual walbro 450
2150 injectors,
e85,
automatic,
dsmlink v3 full,
aem cam gears,
