Eclipse 1998
- 240
- 32
- Jul 21, 2010
Indiana
So the car will not start but cranks over with a weird grinding noise has a new optima battery and fuel pressure is at 46psi when primed, didn't know where to start diagnosing so i started with the spark plugs, pulled my spark plugs and all look good but was researching a bit and don't know if i should go with BPR7es currently using BPR8es car is on e-85, walbro 450 e-85 fuel pump, 1150cc fic's and using flex fuel GM sensors. Any advice? Lastly plugs are in cylinder order in the pictures, #3 looks like it has chocolate milk on it any thought?
