94nonturboGS
- 83
- 0
- Aug 13, 2006
Lincoln,
Nebraska
I'll give that a shot and we will see what happens!
I didn't even know we HAD those... is that only a 2g thing? Or an Automatic thing? Do we need it? Where can we get it? I wouldn't think we would NEED one of those right? ...wow...
Has anybody used any other methods to remove this spacer? I'm having trouble with the toilet paper trick or using vice grips.
I'm guessing I may have to use the air compressor and air hammer?
Where is the thread? id like to read it.I helped my buddy remove his a couple years ago. Here is the thread. He talks about what tools we used to get it out, and it has pics.
Grease packed into it and then use a socket or punch or whatever will go in the hole snug will hydraulically push it out if you smack it and keep packing grease in it. Yes it is a bit messy but that is what we used to remove pilot bushings in farm trucks crankshafts and usually used an old input shaft as the tool of choice for the correct diameter to fit in the back of the crank. Just MTC.
