caged
- 104
- 0
- Jan 2, 2009
Brisbane,
Australia
Im about to install a set of Manley single valve springs #22125-16 and Ti retainers #23125. Im using a set of kelford 272's and run 40psi @ 8750rpm on an EVO 3 4g63, I was on std evo 9 springs, seats and retainers but think im well overdue for an upgrade. Manly has 2 different part#'s for springs, one to suit DSM 1990-1999 and another to suit EVO/DSM 1990-2008 (I have these ones). Both use different retainers with the step at different heights, My Question is can I just shim these up a bit? and have I ended up with the high lift version? Max lift on the dsm spring# is 0.460'' with seat pressure [email protected]'' and the Evo/Dsm# I have is max lift .580" with seat pressure [email protected]".
I would need to shim it 0.12 ( thats huge) just to get it back to the seat pressure/max lift specs of the dsm spring???
Manley Performance - Sport Compact - Mitsubishi - 4G63 / 4G64
