Dragnous
- 294
- 18
- Nov 29, 2014
Clearwater,
Florida
So I Driven my car for the last few days now and a problem that has been on an off for a time is well back.
I will start the car and all seems well.. at random points I will be pressing on the gas pedal and It will start acting like its choking. If I lightly press the pedal it will stabilize a bit but if i give too much gas it will act like its getting no gas.
My First thoughts is that since the car has been sitting for the past month and a half the gas may have gone south. Is this really enough time for the gas to collect water and deposits?
My second thoughts as this problem has been around before is that maybe my injectors are dirty or getting bad. Does this sound like something that would happen?
Thought about Fuel pump but it does look as though it was replaced by PO before I got it. I guess this does not mean its not having issues but low on my list.
Also when i idle it starts to get kinda rough at times too.. under 1k rpm. If i give gas will recover.. Hence why I am wondering if its the injectors
Note: Not overheating as i know this can cause issues as well..
When scanned it does give off code for O2 however been awhile so will need to get this re scanned to update memory.
