Sp00lin16g
- 51
- 0
- Jun 29, 2015
Cleveland,
Ohio
Does anyone have or know where I can get couplers that will fit the injen intake .. my current couplers are hard and may be causing a boost leak??
Thanks guys
Thanks guys
ok thanks for the info .. the larger coupler is an oval, will that work?That seems strange. My Injen intake couplers are all before the turbo & would make any difference for a boost leak. Could mess with MAF metered air though & cause running lean maybe. Anyway couplers can be bought from just about any one of your favorite vendors & there many really goods vendors on here & support our community that you can go to & support. The big one is 4in & the small is 2-1/2.
Ok that sounds good I'll check out ebay, thanks for the infoIt's round, you gotta stretch it to fit the oval. Just order some silicone couplers from eBay. I think mine were $10
Would you go with silicon couplers?Ok that sounds good I'll check out ebay, thanks for the info
The 16g intake inlet is 2.5in?That seems strange. My Injen intake couplers are all before the turbo & would make any difference for a boost leak. Could mess with MAF metered air though & cause running lean maybe. Anyway couplers can be bought from just about any one of your favorite vendors & there many really goods vendors on here & support our community that you can go to & support. The big one is 4in & the small is 2-1/2.
Good call on the siliconeintake ... they're sold out of the 2.25 in tbolt clamps ahah and I needed oneSiliconeintakes dot com will have anything you ever need... before speed density i got a 45 degree hose for bov return too...
Not trying to steer you anywhere just have had great experiences with them
If its for your turbo inlet just get a home depot hose clamp.. tclamps are better but those will work in a pinchGood call on the siliconeintake ... they're sold out of the 2.25 in tbolt clamps ahah and I needed one
I don't think so at all. They don't dig into the couplers when you tighten them up.Personally I think T-bolts before the compressor would just be a waste of money.
