Austin Jedrzejek
- 110
- 5
- Apr 23, 2015
Cleveland,
Ohio
Does anyone know anywhere I can get all my transmisson seals ( input, output, axle) replaced for cheap. Thank you.
Guess youve never taken one apart. This is no small task. Tcase output is no big deal. Input? I wouldnt do it cheaply. Several hours labor minimum plus the non replaceable parts.I'm not going to lie, the input shaft seal is critical and a royal pain to get to. As stated, the entire trans needs to be pulled apart to get to it, I tried, there is no way to sneak it. If you try it yourself do research, look at pics, take pics, label everything and be patient.
Or drop the trans off at a local shop. The majority of the fees are usually pulling and installing the trans, so if you just drop off the trans I can't see how they would charge much
