Smilinjay
- 290
- 97
- Jul 9, 2013
Anchorage,
Alaska
Let me start off by saying that I'm putting this in the newbie forum because i'm sure similar topics have been covered before. And, well, im a newbie when it comes to building shortblocks.
So I pulled the oil pan off of my 90' tsi awd the other day and discovered about 20 large pieces of bearing material. After pulling the rod and main caps, I found the center main bearing was trashed. So I guess its time for a rebuild.. The car only has just over 100k on it but by the looks of it, the previous owner(s) weren't too kind to it. Perhaps letting it run too low on oil. My power goals are relatively modest as this is predominately a street car, so I would prefer to not buy aftermarket rods and pistons.
Anyway, I want to do this once and do it right. So im going to post a list of what machine work and parts I am going to purchase. Please speak up if you see things missing from my list or if you see parts that are not entirely necessary!
New oem evo 9 pistons and rings (I found a very reasonable deal on a set, and would prefer them over running 2g pistons)
ACL main and rod bearings
ARP rod bolts
ARP main studs
oem composite head gasket
oem timing belt auto tensioner
Felpro shortblock gasket set
Balance shaft eliminator kit
I already have a water pump, gates timing belt, and arp head studs with with only 500 miles on them.
Machine work:
Crank polished
bores honed
pistons machined for 22mm wrist pin
Hot tank the block
The machine work comes to $375 all together, which seems very fair to me. Anyway, pleas lmk if I my list is missing anything.
ARP rod bolts
ARP main studs
Machine work:
Crank polished
bores honed
Hot tank the block
