rough
- 800
- 74
- Nov 12, 2012
Indianapolis,
Indiana
Problem -- Hitting fuel cut around 5k rpm --
Mod Break down
E3 16g
660cc Injectors
255 fuel pump
FMIC w/ Hard piping
HKS SSQ BOV
bpr7es plugs and NGK wires.
Aeromotive FPR
3" Exhaust
Shimmed Wastegate
Small boost leak at throttle body shaft - drop's 1 psi about every 3 seconds, system holds 30psi.
This can't be my fuel cut issue.
I'm hitting fuel cut all over the place!! My logs are showing injector pulse width hitting 0 around 5500 rpms.
Doesn't matter if i'm on waste gate pressure or have it turned up to 20psi.
I've set my tune back to stock, had no effect on the fuel cut.
I've attached a log.
Here is a video of the violence.
I feel I've searched the internet for a good 10 hours looking at anything named boost leak, fuel cut, ect, and nothing has altered my situation.
What I'm looking for is any help, advice, solutions to this problem if you had it before!
Thanks!
Mod Break down
E3 16g
660cc Injectors
255 fuel pump
FMIC w/ Hard piping
HKS SSQ BOV
Aeromotive FPR
3" Exhaust
Shimmed Wastegate
Thanks!
