Still have some honing questions
cj8990
97
Mar 20, 2010
Chicago, Illinois
So I've verified my cylinders are not out of round, tapered, or egg shaped. All specifications are within limit but I need to replace my piston rings because I broke one.
At this point I can just hone and replace the rings but after researching I still have some questions on the honing process as I've never attempted it before.
-How long do I go for?
-How dense should this crosshatch pattern be?
-Indicators of when I've honed enough?
-Ball hone or three prong style?.. I've seen people say one or the other.. any merit or do they both do the job?
-I've seen the terms honing and de-glazing both used for the same process.. Are these the same or is there a difference?
thanks for any and all help,
-Corey
The tem "honing" is a very loosely used term.
If you stick it on a drill... thats a deglaze
You bolt it in a machine, and can actually remove some metal, Thats honing
You can not get in much trouble with either a 3 stone hone or a Dingleberry hone
Neither applies much outward pressure to the cylinder bores
Crosshatch needs to be in the 45*-60*
You know when you hone enough, when you see it, or you have gotten the measurement you want.
Now the question is what grit to use.... That depends on what rings you run and what finish you want.
Thanks for the reply..
How would one determine what grit to use if they haven't decided what rings? (and by which rings you mean the manufacturer or the size?)
What are the benefits and drawbacks of different finishes? (by finish do you mean how dense you make the crosshatch on the cylinder?)
thanks again,
-Corey
different ring materials use different cylinder finishes. Go to JE proseal's page and read about it.
Typically for a 4g you will have a nitrided steel top ring and a iron second ring. They generally want a pretty fine finish and then plateau honed.
In the home garage it will be very difficult to exactly produce these finishes. Get a 280grit ball hone rough it up a bit and go.
contrary to popular belief, when using non-hard faced rings it is not necessary to do anything to the cylinder before installing new rings.
(i was thinking the full set of rings OEM is iron, been a day or 2 since i seen the OEM ones in my hand though so you should verify that)
you seem to not be doing a full rebuild or anything exotic, just get regular rings and put one new one in place of the one broken one and go on about your day.
if you want to put brand new rings on all the pistons but you are still going to use the original pistons i also would in no way touch the cylinders with any tools. the new rings will conform to the pre broken in cylinders no problem, where as if you do have them honed clearances will be changed and you may or may not end up with a good ring seal.
if for some unknown reason you feel like going with plated rings, you will need to bore and crosshatch the cylinders and use new pistons to get it to seal worth a dang.
I have done hone and go, builds and full bore builds both with and with out torque plates.
Maybe I am a bit to old school, But I would not ever drop new rings on an old cylinder finish.
The factory rings are nitrided steel first / and Iron second. Virtually all jap engines are like this. Especially turbo stuff.
Never use chrome rings in a turbo engine. It will cook the plating off.
