enriquez2000
- 2,277
- 820
- Oct 5, 2014
fort collins,
Colorado
Im averaging 16 or 17 was wondering if this is on par with other dsm cars.
Didnt you have issues at that afr? I just upped mine to 15.1 and it feels weird not seeing 14s
This is mine as well!about 16-18 mpg on e85. Hard to stay out of boost
My best e85 mpg was on an older tune. I think my current tune may top it. But driving 122 miles to MOD getting fine tuned on the driveabilty and doing some wot pulls. Was seeing 26-27mpg.
this past winter untuned pig rich I was getting 15mpg. I have a new tuner who was very disappointed how the old map looked. so I'm curious how the new tune will end upId love to see that tune. Thats 10mpg over most of us
Whats your cruise rpm 3300?Mine did 21-22 long ago on E85, heres the setup
91 AWD stock 5th gear
Stock N/T Engine
Stock n/t cams
China 16g at 20psi
CX racing $59 FMIC
450cc injectors
Stock ecu - No maft, afc, link, ect.
Super hacked 1g maf.
Walbro 255HP
AFPR at 60psi base fp,
JAW wideband with NB simulation fed into the ecu. Switch point set at 16:1
With this setup the car actaully ran great. The high fuel pressure along with the super rich factory fuel tables and E85 produced a WOT AFR of about 12.5:1, and it cruised and idled at about 16:1. I ended up going 13.07@107 like that. It should have gone faster as there was a little fuel left, but I didn't know much back then. Going to revisit this with my Galant GSX and a 14b.
With my current setup, holset, 1500cc injectors, maft, 2 x 255, ect. I get about 16-17 on the highway cruising at 15:1 and 80mph.
I tried the do super lean cruise and it didn't work out very well. On the cruise control it was always hunting for speed. It was like it wanted more throttle angle than the cruise control thought it needed, and it would back off and slowdown to much.
gofer said:I keep a good record of every fill up, as well as comparing my 91 oct MPG's vs. my E85 MPG's. Assuming E85 hovers around $2.89ga and 91oct hovers around $3.47ga, which we all know isn't going to happen...E85 STATS
E85 Price: $2.89ga
E85 MPG: 18mpg
E85 cost per mile:$0.161
E85 miles per dollar: 6.22891oct STATS
Gas Price: $3.47ga
Gas MPG: 24mpg
Gas cost per mile: $0.145
Gas miles per dollar: 6.916 Best
How everything adds up...
Miles you drive per year: 12,000
Cost per year, fueled with E85: $1,926
Cost per year, fueled with gas: $1,735
Gasoline not imported by fueling with E85 (per year): 400 gals
Reduction in green house gases with E85 (per year): 2,883 lbs
