TiniacosMotorsports
- 34
- 1
- Nov 25, 2014
pensacola,
Florida
Looking for info and parts for the best stock turbo setup. Such as fmic,bov,exhaust,downpipe. And any other helpful mods. 97 eclipse gst 5 speed.
Buschur racing has a nice upgrade sequence that I recommend going off of.Looking for info and parts for the best stock turbo setup. Such as fmic,bov,exhaust,downpipe. And any other helpful mods. 97 eclipse gst 5 speed.
Yes. I wanna stick with it . Wanna try do stay on stock turboAre you determined to stick with the T25?
I honestly don't see a point in link if your going to run the t25 unless you want to practice tuning. The t25 is pushing its efficiency at 15psi and the stock 2g side mount will heat soak after 1st-2nd gear @ 15psi and link isn't going to help you with that. If your gonna run the stock turbo/intercooler link would be the last thing on my list. You wont need link until you decide to go with a bigger turbo which will require a better intercooler, larger fuel pump/injectors, wideband, and fuel pressure regulator. If those are your plans then link would be a good idea bc your going to need it eventually. If your gonna stay with the stock turbo/intercooler you don't need link, it would be a choice of you wanting to mess with tuning. Tuning is going to require some research, trial and error, and probably some dyno tuning.
Third i went 12's on a 14b and stock side mount and know others have gone faster.
