FLASH1970
- 1,265
- 9
- Aug 22, 2005
Lake Geneva,
Wisconsin
As the title says, I have a 92 Talon that sparks once when I first start cranking. I can keep cranking and get nothing. Then when I let go of the key, I get a spark. Not sure what's going on. Coil tested out good (13.2 & 13.4 I think on the secondary coils. Primary was .1 but that's as accurate as my multimeter goes), just had the ECU rebuilt by ECMlink, MPI relay clicks, did a point to point test on the wires from the ecu to the coil and they were good. Got any ideas? Thanks in advance.
