2G running ruch
Icooper81
Mar 21, 2015
Palm Springs, California
So i have a 97 eclipse gst that is running horribly rich. If i yake a drive down the street and back i will lose a decent amount of gas..the only i have done to the car is a 1g bov and changed the fuel pressure regulator.also while driving it smells like gas in the cabin.Any help please.
I believe the regulator is working properly...and how would i set the pressure??
You changed the fp to what replaced the stock one, shouldn't be rich, to changing that loosing gas I would look for a gas leak.
I
I think im losing gas..im going to order a fuel filter tonight..but i dont see any leaks on the fuel rail or where the fuel filter is..so im lost
Does the car spudder or anything like that? If the car is throwing black smoke then you're definitely running rich, but you're smelling a strong odor of gasoline then there might be a gas leak...
the car does sputter under heavy acceleration..early this morning i took a look at the fuel pump and sending unit..and before i even took off the plave for the semdimg unit it smelled horrible of gass..i took a look at at it..it looked fine..so i tightned it up amd called it a day..doest smell that bad anymore
