wvdsm92
- 74
- 8
- Feb 20, 2013
Elkview,
West_Virginia
ok i have it tdc all the marks are good, the lifters are bleed but i can not turn the motor at the crank and even when i have the belt off and try turning the cams with a wrench it was very hard then i loosened the cam cap bolts and it was easier to turn but seemed like it was still too much effort. so i left the bolts loose on the cam caps put the belt on put gave it tension with all the marks lined up still couldn't budge it at the crank. the crank spins easy by it self. anybody have an idea?
