ECMlink Link v2.5, maf-t and 1600cc injectors
Bluefire16
1,500
20
Mar 30, 2007
Grand Rapids, Michigan
Alright guys a couple questions, I have windows 7 on my computer and will be using dsmlink 2.5. However i am not sure what file to download and run. None of the downloadable files are for 7 and or for link 2.5. Little confused what to use
Secondly i have some 1600cc injectors i will be using with e85. How do i set this with the maf-t and dsmlink? Maf-t doesnt allow you to set 1600 injectors.
Sorry im new to tuning...
You can use the standard link app with 2.5 and windows 7. It all works fine. As for injectors, I would zero out the MAF-T and use Link to compensate for the injector size. Its a straight forward input in V3. I'm not 100% sure on 2.5. Personally, I would try to upgrade your 2.5 to V3, and use a MAF cable from the ECMtuning guys to run the GM MAF directly to the ECU. You could sell the MAF-T to recoup some of the loss.
