- Thread starter
- #201
teknicalissue
- 303
- 3
- Oct 18, 2010
Front Royal,
Virginia
Yes sir that's why you have people here backing you! What do you mean by heated? At least you found some badass little motors in the process. I think using belt drive would be the best as far as simplicity while using the same motor you were going to for direct drive so you can really get into the compressor efficiency range. Additionally, using a Larger compressor (ie. HX-35 or similar) paired with that motor and you've got a hell of a lot of airflow!!
I meant geared not heated sorry, I'm still traveling and thinking about this On my way to the airport.
I can't see the image on my phone but I'll take a look at the airport. What would be the difference between a belt and a gear driven system? Which one is more efficient and can belt system hold high rpm?
