Ohhchhittt
- 115
- 2
- Oct 20, 2014
Naples,
Florida
yes I searched,
So I was messing around with my car cause something was not right. I lost 2 lbs of boost some where.
Thought it may be a leak. So I tested it. Seems good. Holds lbs with a really really slow let off.
I tried diff things removing hoses and re fitting them. I bypassed the BCS and ran a hose from the turbo to the WG. Ran good held boost this time around 8-9 psi. So I thought it may be the bcs. I installed the T on the turbo/WG hose and ran the other end of the T to the intake nipple. WOW. BOOST LIKE A ..... Hit 18-19-20- think it even hit fuel cut off. At 20. When I took off it would spool up to 18-20 and drop to about 14 and hold. But if I was in 5th and stepped on it I wouold hit 20 and it felt like fuel cut off. Put the bcs back on and steady 10-11. sorry if this post is all over the place. So the issue I had seemed to go away when I put the BCS back on. But the ? I have. By bypassing the BCS the way I did why was my boost all over the place. I have read you can bypass it.
Thanks for the help guys.
