How To Make Tach Light Up Red At Redline?
jjw205
327
15
Aug 4, 2006
Syracuse, New_York
Been trying to figure out a way to do this, and finally found a video showing it. Any ideas to make this happen?
I ran into this video a whIle back and would love to do this too.
If you do as johnny says that means it will light up to detect knock as well or if there's a code thrown. If there's a way to separate both functions I would be more inclined towards that.
Yea there has to be a different way, I don't think that's how he has it set up. Maybe some type of 2-color LED that is somehow triggered by something. I could probably trigger it in ECMLink but I just don't know what bulbs to use or how to set them up.
I don't know how that's done but this is how I would do it...
Get a cheap shift light then remove led and split it into 4 or 5 led with wires(I don't remember how many bulps behind the tach right now) and stick them next to stock bulps (this means you have to drill the cluster) shift light's led are brighter than stock bulps so when hitting redline it would look like a transition from stock to bright red.
Go to auto parts store and look for side emitting led strips. I know walmart has them, not sure ifnthey carry red but look around. The reason for this is the stripe already has the neccasary resister to drop the voltage for the LED. Pop open cluster find a way to rout the strip. Now you can either use the MIL or you could run the ground of the strip to the unused pin for the purge canister or fuel pressure regulator then set link up to ground that at ur shift rpm. The hot sude of the strip just needs 12V so you can tie that to anything you want
That's probably the only way to do it. I will give that a try and I'll post up some pics if it works.
Anyone have any other ideas besides tying up an output from the ECU? The guy in the video had a 420A, so there has to be another easy way. I don't want to use my last solenoid output on this if I can help it...
Most accurate way would be the way tmoney20g mentioned. However owns the one I the video should recalibrate theirs, turns red 1000rpms below red line.
There's no point of revving that high (all the way to the redline). In my opinion- you just need to know where most of the power is and then calibrate it to light up slightly more above that point.
You can always use any free light in the cluster (I have AT cluster and maybe will use it in my MT talon- so AT lights in the middle of it are free to use). I believe ABS light has additional slot for a bulb etc. so if you don't want to disassemble your cluster- this approach can be used :)
