mbyoung424
- 148
- 6
- Jul 19, 2007
Alexandria,
Virginia
So, I know a Tsi shouldn't be on a two wheel dyno without specific modifications. There's plenty in the tech articles as to why that is true and what needs to be changed if you want to do it.
My problem is that I took my car to get the emissions inspection done in VA. I had just taken my Passat W8 to the same place and they didn't put it on a dyno so I had no reason to think they'd do so with my Talon. I turned my back after they pulled the car in and heard them start revving it. I turned to see they had it on the dyno with just the rear wheels spinning. I immediately ran towards them yelling to stop and they did. I then noticed a puddle of liquid under the car and about lost it. Luckily, there was a trail of this unknown liquid leading up to where they had the car and it turned out my steering rack had sprung a leak in their parking lot.
I failed the emissions inspection and didn't try for the safety inspection as I knew I'd fail that too so I've only actually driven the car twice since this happened a few months ago and just finished working on it yesterday. I didn't notice anything wrong after this incident, has my DSM luck finally turned or is there an impending catastrophe I should expect when I start driving this car again?
