Demizee
- 1
- Feb 4, 2015
Bridgeview,
Illinois
Hi everyone I'm new to the dsm game and looking to do the regular maintenance necessary for my car to run normal. I already have spark plugs, wires, oil, and pcv valve changed and I'm looking at doing the fuel filter next, I just purchased an oem filter from extreme psi and I'm going to install it as soon as it arrives. Only problem is I want to be absolutely sure where the filter is located and what I need to do it. I've done filter changes on other cars and they've all been located right underneath the gas tank but upon a little research on 2g dsms I've found it could either be underneath the battery or under the passenger side so a little different from what I'm used to but I want to be sure where it is because I don't have much time between work and school but I refuse to take it to a shop for a simple job like this. It's a 99 gst and thanks in advance!
