2G Running Rich/No Power Any Help Is Nice
marcus28504
33
Dec 4, 2014
Woodinville, Washington
I have an 1996 Eagle Talon Tsi
Mods are
ECM link V3
3.5in Turbo back with a high-flow cat
TD05 Big16G turbo
Manual Boost Controller
MSD Sparkplug wires
VRSF FMIC
Greddy Type S BOV
MTX wideband
AEM boost gauge
K&N Short Ram air intake
780cc injectors
Walbro 255
Bocsh High Output Alternator
Aeromotive Adjustable Fuel Pressure Regulator
Runs beautiful but no boost, Boost Gauge shows that im getting boost and i finally feel it at 5k rpm
the car use to put me back in the seat and spin the wheels
My Wideband Shows that im running at 10.1 When i hit 3k rpm which it use to be around 12-13 ish
Fuel Pressure Is good
Spark Is Good
Wastegate is Good
Thottlebody is Good
Compression is Good
Turbo is Mint
I have tried to run several boost leak tests and I couldn't locate any boost leaks accept a very tiny one on the bov adjustment screw
This all just recently happened and there has been no change in the Car Tune at all.
I Can hear a slight howling when i drive also seems to be rpm based where its more prominent under 4k rpm
seems to be located under the throttle body Throttle body is rebuilt and has no leaks Biss Is Set
vacuum at idle is 18-22 Idle is set at 900
Any Ideas?
Maybe your exhaust leak got bigger if its before the turbo I would definately fix that first.always fix the obvious first.
The Exhaust leak is smaller, But My Car also through an EGR code during the datalog, could an egr valve cause a no boost scenario
Mods are
ECM link V3
TD05 Big16G turbo
MSD Sparkplug wires
VRSF FMIC
Greddy Type S BOV
MTX wideband
AEM boost gauge
780cc injectors
Walbro 255
Spark Is Good
Wastegate is Good
Thottlebody is Good
Compression is Good
Turbo is Mint
Any Ideas?
Did you check the wastegate maybe?
if you are getting the psi that u usually get on the guage and you are running rich. Maybe your tune or ecmlink messed up. If you are getting to much fuel and you have a stock fuel pressure reg it could of went bad and you are just pushing more fuel. A easy way to check is take the vacuum hose off it plug the hose and take it for a run and if it feels like it did before then something is wrong there and i recommend a after market fuel pressure reg because stock with a 255 can go bad.
If its not that it is possible you are losing boost in the head. head gasket and multiple other things could of gone wrong. but again this is only true if you hit the gas and if you are boosting if you are getting 15lbs like your were before and set for that then its a real good chance of these 2 problems
If you are not getting any boost leaks from the pressure test and your psi is what it was before but it is not going like it did before its a after the intake problem. I would hope of course you have your boost gauge plugged in somewhere in the lines on the intake.
Okay I think I found the problem, I tightened up the BOV Adjustment screw a couple of a turns and Im getting some boost now, but the car almost stalls when I let off the gas ( 200-300) rpm
So Its either a vacuum leak or a bad BOV ?
My fuel system is not stock
Check your O2 sensors and check for exhaust leaks.
02 sensors are new oem Sensors
That's odd you didn't determine your BOV leaking during the boost leak test. Is the BOV recirculating into the intake or venting to atmosphere? What's the wideband doing when it tries to stall? Also might need a BISS screw adjustment.
if you bov was bad then you did a shit boost leak test man. testing by putting a tester on the front of the turbo and pump it up 4 psi more then you are running not pump it up to 4 or 5 psi..
I did multiple boost leak tests that way and I mentioned very early on that I noticed the bov leaking.
its recirculated. My Wideband Goes full rich under boost then goes into 24 vacuum when I coast
you say you have Link V3? have you logged the car while it is presenting the problem? if so look at your airflow.
I had a similar problem with a car. turned out the MAF was going bad. replaced the maf and the car was fixed.
that is what link is for. its a great way to detect and diagnose issues.
1). Any boost, vac, or exhaust leaks?
No
Boost leak tested 5psi above your max boost with no leaks?
Yes
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: Magnacore/1 year
Spark Plug brand, type and Gap: NGK-BPR7ES/.021 to prevent spark blowout
5). Motor health (Compression Test)
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
6). Performed basic throttle body adjustments?
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
8.5:1
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 12.4 volts
Car running: 13.9 volts
Base Fuel Pressure: 43.7
Injector Size (cc/min): 850
Sensor Brand: LC1
Calibration Date: Sep2014
13). Type of fuel
Type: 93 Octane
Percent of Ethanol: 8%
14). Watched ECMlink how-to videos?
Yes
Here's the template. You already took care of most of these it seems but its always helpful to fill it out. :) At least fill out all what you know FOR SURE.
Small Exhaust Leak
Boost leak tested
Yes
Yes
Yes
4). Ignition system
Wire brand and Age: Taylor Wires 8mm Less Than A week old
Spark Plug brand, type and Gap: NGK-BR8ES/.027
Cylinder 1: 150
Cylinder 2: 152
Cylinder 3: 149
Cylinder 4: 151
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
8.5:1
No
Evap Solenoid And EGR malfunction
Injector Size (cc/min): 880
Sensor Brand: LC1
Calibration Date: unknown
13). Type of fuel
Type: 93 Octane
Yes
I figured out why i was running rich (Bad Spark Plug Wire), Now to Fix The bov/ boost leak and see if everything comes back
If you need a new diaphragm, go around motox shops and ask for a rear inner tube that they're throwing away or don't need, just make sure it's in good condition. Make a diaphragm out of that if you need to, it works great, just ask Justin :) Just cut it to spec its not very hard, mine works great. Or if you have a spare piece of thin silicone laying around that is big enough, that works even better.
the Adjustment screw was all the way out
t
