mercaholik
- 465
- 49
- Mar 1, 2014
Warwick,
Rhode_Island
I just read about a new product from Forge called the intake pressure compensation valve. It says it increases load on the internal piston or diaphragm of the dump/diverter valve ( aka blow off/recirculation) helping it form a "superior" seal, irrespective of boost pressure. In doing so, the ipcv allows equal or greater pressure on the top side of the piston or diaphragm of a DV, allowing it to make a better seal against it's seat. This prevents the DV from opening under high boost, load or rpm, and prevents the need for need for a stronger spring. Thus allowing the use of a weaker spring that allows much faster valve response from the DV. Sounds great in theory, I'm gonna pick one up eventually and if anyone has bought one, does it actually work?
