jbeaton9292
- 847
- 72
- Aug 29, 2013
Sterling heights,
Michigan
so ive been thinking about what im going to want out of a future setup. the next car is gonna be a full blown track car not daily driven like all my others have been, so im wanting to go all out and have something nobody else has. so im thinking a sequential turbo setup would be really cool to do. this way i can have low end power that we all seek while being able to make a pull through 10k rpm without dropping off. maybe this is wishful thinking but this is the first im reading into this. if this is how it can work then why arent more of us doing this and making some crazy power and screaming all the way down the track. i feel with the proper setup this would be an awesome setup for road racing on them big tracks.
so here is what im thinking something like a t28 as a primary and a huge like a super 99 or bigger. this way we can make boost very early on in the rpm range because of the t28 (which have made pretty good power numbers) and it in turn will spool the super 99 with a now higher flowing exhaust gas then what comes from the exhaust runners. so now when the t28 has had enough and starts dropping boost the super 99 will be already making power and going pulling like crazy and will have all the air we would need to finish the run without falling off.
now i know that with what im thinking the t28 probably wont live very long but being a track car not a daily that is something that can be taken care of more frequently. also i know with all this added torque it will cause havoc on all the driveline parts. i would want this for an auto car in all honesty so that it dont drop boost when you shift and snap hard on the drive and will not die down.
now what im not sure about how does something like this work as for setting boost. im assuming this would have to be some crazy sort of twin scroll setup. and find at what boost the t28 will begain to spool the super 99 and set the wastegate for said amount of boost and then it would dump just like a single turbo setup. except the boost produced going into the super 99 now and building boost on that. because correct me if im wrong but adding boost to in engine is kind of like adding displacement, i know its still a 2.0 but with x amount of boost on a 2.0 is like running a 5.0 liter which i know wouldnt have a problem with a super 99 strapped to it.
if im right with all of this why arent we doing this more often with our engines. then if we even went 2.3l would could spool something like a hx35/40 for a primary like we would spool a stock frame trubo. i think our power and trap speeds would just be that of a different world that people wouldnt ever see coming till it was way to late.
sorry this seems like a big mess im trying to think about all this new info and how its gonna work
