Street Build 87 Mitsubishi Starion 4G64.3 Swap Time
C89ZX7R
122
23
Feb 24, 2011
Richmond, Virginia
STILL BUYING ENGINE PARTS.
* Build List "Parts I Currently Have"
6-Bolt 4G64 Wideblock
6-Bolt 4G64 Crankshaft
6-Bolt 4G63 Dohc Cylinder Head
6-Bolt Pauter 156mm X-Beam Rods
Jay Racing Billet Main Caps
Kiggly Main Girdle Brace
Kiggly Racing Beehive Valve Springs
Ferrea Stainless Steel Intake & Exhaust Valves
Ferrea Intake & Exhaust Valve Guides
GSC Power Blue Intake & Exhaust Valve Stem Seals
JDM Evo 8 Intake Manifold
Holset HE351CW Turbocharger
Arp Head Studs
Arp Main Studs
Jay Racing Front Water Outlet
Jay Racing Blank Coil Plate
Jay Racing GM Alternator Relocation Bracket
Shaved Dual -AN'd Valve Cover
Magnus Fuel Rail
*Parts Being Used From Previous Motor
Aem EMS-4
Aem Smart Coils
Aem FPR
Aem Boost Solenoid
KDM Mpi Intercooler Piping
KDM 4" Intercooler
KDM Radiator
KDM 3" Exhaust
Greddy Type-R Bov
Motorad High Flow Thermostat
Fenderwell Cold Air Intake
Current Installed Mod List
Drivetrain Modifications:
Competition Stage 4 - 6 Puck Sprung Clutch
Short Shifter
Poly Transmission Mount
GNT Torque Tube Bushings
GNT Differential Mounts
Suspension Modifications:
S&M Front Tri-Point Strut Bar
S&M Rear Strut Bar
Cusco Front Adjustable Camber Plates
Eibach Pro Lowering Springs
Front Suspension Tech Larger Sway Bar
Rear Suspension Tech Larger Sway Bar
Brake/Wheel Modifications:
Abs Bypass Line
Refinished & Polished Rims
Datsun Z Brake Reservoir's
Slotted & Drilled Rotors
Interior Modifications:
Tan and Black Leather Interior
Autometer Carbon Fiber Boost Gauge
Innovate Digital Wideband
35% Madico Tint
Push Button 2 Step Shifter Knob
Console Hi/Lo Boost Switch
Aem Usb Ecu Port
Electrical Modifications:
GM 110 Amp Alternator
Red Top Optima Battery
Welders Wire Battery Relocation
Custom Relayed Cooling Fan Harness
Putco H4 Relayed Headlight Harness
Silver Star Zxe H3 55 Watt Fog Bulbs
L.E.D. Modifications:
X2 Truck-Lite 5x7 Led Headlights - 2600 Lumens
X1 White Ashtray Led - 10 Lumens
X2 Amber Front Side Marker Led - 100 Lumens
X6 Red Tail Light Can Bus Led - 420 Lumens
X2 Amber Front Signal Can Bus Led - 100 Lumens
X2 White License Plate Led - 150 lumens
X2 White Reverse Led - 400 Lumens
X2 White Front Running Markers - 260 Lumens
X1 Third Brake Led - 62 Lumens
X3 Door & Dome Led - 80 Lumens
X1 CF12ANL-01 Led Flasher Relay
Replaced Oem Parts:
New Wheel Bearings
New Control Arm Bushings
New Strut Rod Bushings
New Ball Joints
New Tie Rods
New Tie Rod Adjuster
New A/C O-Rings
Other Modifications:
83 Metal Scooped Hood
Anti-Roll Over Valve
Rotella T6
I have two wideblocks. One is a G64B and other is the 4G64. Using the G64B for the mock up build while I order and build the 4G64. Mock up pics below.
P.S. CAR IS ALREADY WIRED FOR SPEED DENSITY USING A 4G63 SENSOR, WAS A DAILY DRIVER FOR THE PAST 12K MILES...
IMG_82450686812187.jpe
nice intercooler routing in that thing
very, detailed? mod list
sounds like a fun project, these engines would be great rwd.
that things gonna cook. (more)
I love the rare early mitsu cars, you have a truly awesome star/quest there, so sad to hear the motor went on you, well at least you got as much fun and joy out of that motor before it gave up the ghost.
Please do keep us all updated on the build man, I'm subscribing to this, I always love to see these awesome old nostalgic cars. kinda shame mitsu does not have an old school style rwd sports car like these to represent todays market.
2.6L trash is out. Found a G64B block in a really tight spaced junkyard.
Yea, Since Im staying 5 speed I need the wideblock "G63B or G64B", 4g63 is a narrow block doesnt bolt up to my trans.[DOUBLEPOST=1413735118][/DOUBLEPOST]
I did a 4G63 swap on an 89 widebody I got for $300. Rust free western car. Used a powerglide. AEM. Made a harness for it.
What turbo manifold is that?
TY, will be using a 1g dohc head and intake manifold modified for rwd.[DOUBLEPOST=1413763924][/DOUBLEPOST]Here is how the old setup ran after cracking all four pistons. Two cylinders had low compression, one ring land was completely broken from the piston.. Still idled great LOL....
Pulled the head off the 2.4L block, OMG that is the worst Felpro gasket I have ever seen. Mechanic must have been a noob to not see that when putting it on.
Cylinders are round but the gasket wasnt. You can see how the out of round the gasket was in this picture.
Picking up Nib Ferrea Exhaust Guides and Arp Head Studs Today for 110 Bux.
[DOUBLEPOST=1417965802][/DOUBLEPOST]Also picked up
Found a used 1g head for 60 bux.
Dude wish I knew how to weld, that intakes going to look nice, oh well, guess I got to learn baby steps first...
View attachment 241327 LOL:D
Are those springs, retainers, locks, also Ferrea brand?
Friend does the welding. He will also be making me a top mount T3 manifold.
Picture of his welds
[DOUBLEPOST=1418204837][/DOUBLEPOST]
Kiggly Racing Beehives
https://www.extremepsi.com/store/product.php?productid=23205&cat=1732&page=1
Found another 4G64 6 bolt wideblock with a good crank in the junkyard today. Will be dropping them off to be cleaned and magnafluxed this week...
Updated the 1st post. Also picked up the turbo for the swap, cant wait. "HE351".... Also just picked up the crankshaft from the machine shop, which said its in great shape. Thats a relief cause factory 6-bolt 64 cranks are really hard to find.
What are you planning to use for a Cam angle sensor and crank trigger? I am swapping my conquest in a few months because I bought it with a siezed motor and I also found a 6 bolt wideblock 4g64 and I'm looking into the options for cam and crank triggers.
It looks like there are some hyundia 4g63's that have a head with 1g ports and have the spot to bolt on the cam sensor. That head combined with a kiggly crank trigger should do the trick. I plan to use ECMlink for my engine managment, I don't know how that differs for you since your using AEM EMS.
Also I take it you're modding the head to move the coolant port to the front of the engine?
using a 1g head so its the 1g cas
Mine is already setup to run and has been with the G54B with mpi using a modded 1g cas, there is no wiring involved on this swap.
Mail call. HE351 to 3" Reducer just came in the mail.
Mail Call, 450 bux later. Seller stated used for 300 miles then parted out the car. There going to the machine shop for a spec sheet, if they dont come out to what the seller stated then we will go from there. Took a cap off and it fits the 6-bolt crank like its suppose to. Caps are labeled Evo 1 - 6.141. Still going to drop them off at the M-shop.
Had the Pauter Rods checked out by Ballo's Machine Shop, yea same shop the Jafromobile uses.
Pin Diameter .828
Big End 1.889
Length 6.141
Rod 1 Weight - 645.7
Rod 2 Weight - 644.6
Rod 3 Weight - 645.3
Rod 4 Weight - 645.7
