2G Bolt size
95tclipser
40
Nov 19, 2008
VALRICO, Florida
I recently bought a e3 16g hot side from a member on this site, however, all of the bolt holes are ruined. I am going to have the holes helicoiled to use a bigger size bolts. I need to know what is the length of these bolts? There are 2 long bolts & 2 short bolts. I will be using an fp manifold. My turbo is still on the car so I cannot get a correct measurement. Thanks
What bolts? The manifold to turbo bolts? If so, these are originally all the same size so we won't be able to tell you what length bolts you have.
Typically when a hole is Heli-coiled, it is modified to refit the original hardware.
Looks like whoever had the e3 16g before I bought it had the holes enlarged & retreaded. Thanks.[DOUBLEPOST=1412347639][/DOUBLEPOST]
I only bought the hot side. Thanks again.
