u2slow
- 154
- 1
- Feb 21, 2004
Lawrenceburg,
Kentucky
I`ve got stuff I need to get rid of. This sale is intended for local pick up only. Everything is for 1g/6 bolt, unless otherwise noted.
$10
g-tech meter (early model)
2g ignitor
2g coil
91+ cas
home made adapter harness for 91+ cas in a 90
oem radiator
Mishimoto twin fan shroud with 1 fan
91+ coil
91+ ignitor
90 FWD driver`s side axle (needs boot)
91+ water pipe for oil cooler
crank pulley
front seats
awd flywheels
jaz radiator overflow bottle
a pillar double gauge pod
assorted gauge holders
center vent 3 gauge holder
valve cover
power steering pump
engine/trans plate
rear engine cover
tmo serial connector
6x9 triaxial speakers
5x7 soche speakers
heat sheilds
various interior plastic
shifters & cables
hvac (any section)
trunk carpet
battery tray/hold down
velocity horn for turbo
a/c compressor
$5
vinyl/dash repair kit
oem hla regulator
oem power steering pump bracket/heat sheild
oem accessory pullies
a pillar single gauge holder
cup holders
eclipse 1g front grill badge
sun visors
console pieces
power antenna
oem dash speakers
oem engine hoist loop
aftermarket front roll stop insert
spark plug wires
oem radiator fan
oem valve springs/retainers
oem fuel rail
oem cam gears
dipsticks w/tubes
91+ water pipes
various intake pipes & pieces
pop up motors
$10
2g ignitor
2g coil
91+ cas
oem radiator
91+ coil
91+ ignitor
crank pulley
front seats
awd flywheels
valve cover
power steering pump
engine/trans plate
rear engine cover
5x7 soche speakers
heat sheilds
shifters & cables
hvac (any section)
trunk carpet
a/c compressor
$5
oem hla regulator
cup holders
sun visors
console pieces
power antenna
oem dash speakers
spark plug wires
oem radiator fan
oem fuel rail
oem cam gears
dipsticks w/tubes
91+ water pipes
pop up motors
