kanusky1990
- 95
- 8
- Sep 14, 2011
Easton,
Pennsylvania
Hey guys,
I searched and found a few threads but none with video displaying the noise.
I recently swapped my rear differential to a unknown condition USED manual LSD rear diff.
At the same time, I swapped in new solid aluminum rear differential bushings. I read and understand that this will increase noise in the cabin from the rear diff.
The noise is much louder than I anticipated and believe it is a combination of a bad rear diff, and the increase in noise from the solid bushings. let me know what you think.
I also had a seized rear axle in my rear hub. I tried removing it with a dead blow hammer with no luck. When I got an alignment, one of the employees noticed the rear noise and suggested it to be a bad hub bearing, not a bad rear .
It makes the noise usually above 35 mph, both accelerating and decelerating. The weird thing is if I am in 3rd gear and engine brake, the noise disappears. Which makes me doubt its the hub bearing.
Any help will be much appreciated. Thanks!
