Kdouglas89
- 436
- 11
- Jul 8, 2013
Davenport,
Iowa
I have every timing mark lined up, I just cannot get the belt back over the pulley.
I have the tension tool with the 2 teeth on them, but I do not have the belt tensioner bolt that you use to release the pressure.
Is there any other way to compress the pressure without the belt tensioner bolt?
Like I said, the only issue I am having is getting the belt back around the tensioner pulley.
Thanks
Thanks
