eclipsek17
- 130
- 5
- Aug 1, 2004
All over,
Arizona
I have went through 3 crank in the past 5 months, each in a different engine, but all three cranks are done already and are trash. Orielies has a reconditioned crank and also dsmgraveyard carries a reconditioned crank, but I am wondering will they hold up or are they a waste of money? My current hp goal is about 450, and I am in the process of rebuilding a engine in excess of what I will be running to avoid problems. I have read that the oem crank is ok for 500 to 600hp, is this true? If anyone knows where to get a oem crank please let me know.
Also I am still learning so bear with me, but is high compression 10:1 and low is 8.3:1 or vice versa? If I was looking at running 30psi, would 9:1 be ok or should it be lower or higher? Also, there is probably a post about this but how do you know how much timing to advance or retard? What does advancing and retarding intake and exhaust cams do exactly?
