1995 brian
- 233
- 2
- Dec 16, 2011
Leadville,
Colorado
Alright so i swapped the engine on my 97 gsx auto and found a nasty transmission leak coming from inside the trans i unbolted the torque converter bolts and pressed in the torque converter i felt it move slightly inward. Could it be the torque converter isn't in all the way? I bolt the torque converter bolts back on and it pusher the converter back out. The trans didn't leak before the swap and is there anyway i can avoid removing the trans. Any help would be greatly appreciated.
