aml15
- 0
- May 12, 2014
far away,
Europe
Hi.
Let me first say that this is not for a dms, but for a old 4wd celica ( st165)
I am having HUGE problems with wheel hoop\stepping as soon as the tires loose traction when running my hoosier drag radials.
This car have been on the drag strip for a few times a year, and the car have behaved good up until recently. could do burnouts\and leave the line spinning.
But at some point the car have been starting to get EXTREME wheel hoop ( really violent stepping) as soon as the tires loose traction. resulting in broken drivetrain parts. ( so violent that even the windshield cracked.)
( 3 rear axels, 2 front axels, and a leaky gearbox all in the last 3 runs where the car lost traction of the line..
The car have never had a problem with hoop before now.
The car have been taken completely apart between these runs, and all bushings are perfect ( poly in everything, including rear cradle,engine mounts,\rear diff bushing)
running Hoosier drag radials, and BC coilovers with 10/8kg springs ( most after-market coilovers are stock with 6 front and 4 rear).
Tested with different tire pressure to lower traction (18,22,32psi) full soft and full hard settings on coilovers=no difference....
It`s really starting to become expensive to try to figure this out.. ( car was doing perfect flat burnouts every time up to a point, and now i can`t even leave the line with wheel spin.
Since the car behaved good up until a point, i would assume something have changed. but can`t see anything wrong ( alignment is perfect\same)
On road tires there is no problems. only on a prepped track with drag radials.
I also do some road racing with this car, and i can`t feel anything wrong with it then either, but is it possible that the dampers is starting to let go? ( can`t feel anything wrong with them at 150mph on a road race track ) but will a bad damper with a hard spring be able to cause this problem?
I hope someone have some hints on what i should look at.
(PS: asking on the evo forum since the celica drag racing community is non existing )
