M1L3S
- 132
- 1
- Apr 1, 2012
maple grove,
Minnesota
You didn't read the two links I posted for you in the other thread. Do so as it'll help you get your idle dialed in. I'm pretty sure your stock injectors don't need 450 usec of global deadtime and your MAF Comp sliders have not been touched.
http://www.dsmtuners.com/forums/ecmlink-tuning-log-file-advice/444831-list-values-log.html
http://www.dsmtuners.com/forums/ecm...efore-you-ask-ecmlink-dsmlink-log-advice.html
Have you checked your DTC codes? You have two of them.
What are you using the EGR solenoid for that you have it activated?
