OWL
- 36
- 0
- Feb 6, 2014
Clarksville,
Tennessee
Hello, I have a 2g engine installed and having issues with the wiring harness. As of right now Im confused on if the engine should have two plugs for the cam angle sensor and where the crank angle sensor should plug in. when I disassembled the old block it didnt have a crank angle sensor, but it was a 7 bolt. I guess what Im getting at is if a 2g should have a cam position sensor and plug into two plugs from the harness, and if so where does the crank angle sensor plug into. It looks like the gray plug going to the cam angle sensor has two wires cut from it on eiter side of the middle wire.
Any input will be good
